[petsc-dev] petsc-dev: ASM with sbaij matrix and block size=1 broken?
Brad Aagaard
baagaard at usgs.gov
Sat Nov 5 00:20:00 CDT 2011
Jed,
I assume you mean src/ksp/ksp/examples/tutorials/ex2
I have not yet been able to duplicate the error with this example. Do
you know of any other test cases that might be appropriate?
My PyLith simulation with -malloc and -malloc_debug flags chokes on line
933 of src/mat/impls/baij/mpi/baijjob.c with a EXEC_BAD_ACCESS.
933 for (l=0; l<nzA; l++) cols[imark+l] = cstart +
cworkA[l];
When the memory error happens at this line, the debugger shows
l = 1400100
imark = 0
cstart = 0
cworkA[l] = 0
cols[imark+l] = -17958193
The address of the bad memory access matches the address of cols[imark+l].
Brad
On 11/4/11 8:39 PM, Jed Brown wrote:
> On Fri, Nov 4, 2011 at 21:30, Brad Aagaard <baagaard at usgs.gov
> <mailto:baagaard at usgs.gov>> wrote:
> Barry,
> Sorry for the hg goof. Here is the changeset that I think is related
> to the problem.
> http://petsc.cs.iit.edu/petsc/__petsc-dev/rev/7782710e3f96
> <http://petsc.cs.iit.edu/petsc/petsc-dev/rev/7782710e3f96>
> If bs=1, then this doesn't change anything. As far as I know, it is not
> possible to create an SBAIJ(1) with map->bs != 1. Can you find a way for
> me to reproduce this? I see no problem with this, for example:
> mpiexec -n 4 ./ex2 -mat_type sbaij -pc_type asm
