[petsc-dev] petsc-dev: ASM with sbaij matrix and block size=1 broken?
Sat Nov 5 00:47:41 CDT 2011
On Fri, Nov 4, 2011 at 23:20, Brad Aagaard <baagaard at usgs.gov> wrote:
> I assume you mean src/ksp/ksp/examples/**tutorials/ex2
> I have not yet been able to duplicate the error with this example. Do you
> know of any other test cases that might be appropriate?
Any scalar symmetric problem can be done this way, but this problem is
fishy and doesn't make sense in any "standard" case.
> My PyLith simulation with -malloc and -malloc_debug flags chokes on line
> 933 of src/mat/impls/baij/mpi/**baijjob.c with a EXEC_BAD_ACCESS.
What do I need to do to reproduce this on my machine?
> 933               for (l=0; l<nzA; l++)   cols[imark+l] = cstart +
> cworkA[l];
I need to hunt around to find out why nzA is bigger than it should be (or
why some array is the wrong size).
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20111104/fc676550/attachment.html>
