[petsc-dev] petsc-dev: ASM with sbaij matrix and block size=1	broken?
    Jed Brown
    jedbrown at mcs.anl.gov
    Fri Nov  4 22:39:06 CDT 2011
On Fri, Nov 4, 2011 at 21:30, Brad Aagaard <baagaard at usgs.gov> wrote:
> Barry,
> Sorry for the hg goof. Here is the changeset that I think is related to
> the problem.
> http://petsc.cs.iit.edu/petsc/**petsc-dev/rev/7782710e3f96<http://petsc.cs.iit.edu/petsc/petsc-dev/rev/7782710e3f96>
If bs=1, then this doesn't change anything. As far as I know, it is not
possible to create an SBAIJ(1) with map->bs != 1. Can you find a way for me
to reproduce this? I see no problem with this, for example:
mpiexec -n 4 ./ex2 -mat_type sbaij -pc_type asm
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20111104/fe5d3515/attachment.html>
