[petsc-dev] incomplete fix for MatSetValuesStencil() someone recently made
    Jed Brown
    jed at 59A2.org
    Tue May 24 04:57:23 CDT 2011
On Tue, May 24, 2011 at 11:27, Lisandro Dalcin <dalcinl at gmail.com> wrote:
> BTW, I use cmake for building. Why I do not get these warnings? Are
> you passing additional compiler flags?
Probably the compiler version. You can add VERBOSE=1, as in
make -C $PETSC_ARCH VERBOSE=1
to see the compiler invocation. The flags all come out of BuildSystem, if
you have an example here they are different, let me know.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20110524/b51191f9/attachment.html>
