[petsc-dev] PCFieldSplit broken, what was intended?
Jed Brown
jed at 59A2.org
Fri May 27 09:01:41 CDT 2011
This is broken even when PCReset() is not called:
changeset: 19062:65bdb5e3e7bc
parent: 19059:6987fe7e0c0d
user: Barry Smith <bsmith at mcs.anl.gov>
date: Thu May 26 22:00:00 2011 -0500
summary: fixed PCReset_FieldSplit() to work in certain cases
I see comments indicating that you agree the code is horrible ("if I got
here, it must mean I was called from X"), but I don't know what you were
trying to do. In particular, neither this predicate nor its negation agree
with the comment.
} else if (!pc->setupcalled) {
/* PCReset() has been called on this PC ...
make runex19_fieldsplit_2
#0 PetscError (comm=0x865dc0, line=312, func=0x7ffff77e1dd0
"PCFieldSplitSetDefaults", file=0x7ffff77e0f20
"/home/jed/petsc/src/ksp/pc/impls/fieldsplit/fieldsplit.c",
dir=0x7ffff77e0d43 "", n=56, p=PETSC_ERROR_INITIAL, mess=0x7ffff77e1280
"Cases not yet handled when PCReset() was used") at
/home/jed/petsc/src/sys/error/err.c:336
#1 0x00007ffff749b09c in PCFieldSplitSetDefaults (pc=0x916160) at
/home/jed/petsc/src/ksp/pc/impls/fieldsplit/fieldsplit.c:312
#2 0x00007ffff749b324 in PCSetUp_FieldSplit (pc=0x916160) at
/home/jed/petsc/src/ksp/pc/impls/fieldsplit/fieldsplit.c:333
#3 0x00007ffff73e27a5 in PCSetUp (pc=0x916160) at
/home/jed/petsc/src/ksp/pc/interface/precon.c:819
#4 0x00007ffff74ccaf4 in KSPSetUp (ksp=0x8de370) at
/home/jed/petsc/src/ksp/ksp/interface/itfunc.c:261
#5 0x00007ffff74cde16 in KSPSolve (ksp=0x8de370, b=0x8a7d20, x=0xaa1510) at
/home/jed/petsc/src/ksp/ksp/interface/itfunc.c:383
#6 0x00007ffff7bc1f0f in SNES_KSPSolve (snes=0x8b1860, ksp=0x8de370,
b=0x8a7d20, x=0xaa1510) at /home/jed/petsc/src/snes/interface/snes.c:3124
#7 0x00007ffff7b7a50b in SNESSolve_LS (snes=0x8b1860) at
/home/jed/petsc/src/snes/impls/ls/ls.c:190
#8 0x00007ffff7bbb3ac in SNESSolve (snes=0x8b1860, b=0x0, x=0x8714e0) at
/home/jed/petsc/src/snes/interface/snes.c:2424
#9 0x00007ffff7b6a210 in DMMGSolveSNES (dmmg=0x857bd0, level=0) at
/home/jed/petsc/src/snes/utils/damgsnes.c:540
#10 0x00007ffff7b621b6 in DMMGSolve (dmmg=0x857bd0) at
/home/jed/petsc/src/snes/utils/damg.c:331
#11 0x00000000004023f7 in main (argc=17, argv=0x7fffffffd588) at ex19.c:155
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20110527/bfa2bf42/attachment.html>
