[petsc-dev] petsc shared libraries on cygwin?
Satish Balay
balay at mcs.anl.gov
Wed May 11 23:01:23 CDT 2011
On Wed, 11 May 2011, Brad Aagaard wrote:
> Under what conditions (configure args), if any, will petsc-dev build a shared
> library on cygwin? I am getting static libraries which are causing linking
> problems when trying to build python modules that use petsc.
We didn't have .dlls working on windows before [with either ms or gnu compiler]
satish
> Lisandro- Do you build petsc4py on cywgin? If so, how do you configure petsc
> and mpi?
> Thanks,
> Brad
