[petsc-dev] petsc shared libraries on cygwin?
    Brad Aagaard
    baagaard at usgs.gov
    Wed May 11 21:43:54 CDT 2011
I should add that the current configure and make logs are available for
the CIG cygwin buildbot if anyone wants to examine things in detail
http://www.geodynamics.org:8009/?project=PETSc
(far right side for cygwin, build 15).
Brad
On 5/11/11 7:30 PM, Brad Aagaard wrote:
> Under what conditions (configure args), if any, will petsc-dev build a
> shared library on cygwin? I am getting static libraries which are
> causing linking problems when trying to build python modules that use
> petsc.
> Lisandro- Do you build petsc4py on cywgin? If so, how do you configure
> petsc and mpi?
> Thanks,
> Brad
