[petsc-dev] broken petsc-dev related mesh?
    Jed Brown
    jed at 59A2.org
    Sat Mar 12 13:58:07 CST 2011
On Sat, Mar 12, 2011 at 20:52, Barry Smith <bsmith at mcs.anl.gov> wrote:
>  I removed the file. There is DMLocalToGlobalBegin/End()
That is not the same at all, it involves communication while
DALocalToGlobal() did not.
>   Can't you do this with LOC=/someotherplacewhere you are putting docs
I typically run with LOC=$PETSC_DIR/docs, but makefile.html and all the
*.c.html still go in the source tree ($PETSC_DIR/src/...). I would prefer to
have them go where LOC points instead of necessarily next to the source
files themselves.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20110312/ff1579c2/attachment.html>
