[petsc-dev] broken petsc-dev related mesh?
    Barry Smith
    bsmith at mcs.anl.gov
    Sat Mar 12 13:52:05 CST 2011
On Mar 12, 2011, at 12:07 PM, Jed Brown wrote:
> Matt moved dm/mesh to dm/impls/mesh, but did not update the makefile. Fix pushed.
> I would like to encourage running config/cmakegen.py --verbose occasionally since it shows stale things in the source tree, and stale makefiles. Some cases:
   Satish,
    Please add this to the nightly test process and have it dump a webpage with the crap results.
   Jed,
      Thanks for pointing this out.
> src/sys/draw/impls/x/xvgrab.c has been both removed from the makefile and has #if 0 around its contents.
   Removed
> Was the latter just to appease builder.py which (at that time, not sure now) was not checking makefiles? cmakegen.py parses the makefile to determine what to build. One reason to prefer that model is that it becomes easy to list those files which are not being built at all.
> src/sys/adic/adic/alloc.c is not a C source file at all, it hasn't been touched since it was first checked in in 2005.
   Removed
> src/dm/impls/mesh/examples is not declared in the makefile, it would be consistent to move these to src/dm/examples, but many of the examples depend on SNES which is a higher level concept than DM, in which case they don't belong in DM at all.
   I'll leave this Matt
> The function DALocalToGlobal() vanished in the DMDA reorganization, the implementation is sitting in src/dm/impls/da/daltog.c but this file is not being compiled. Doesn't this functionality actually belong in DM, in which case it needs to be hooked back up?
  I removed the file. There is DMLocalToGlobalBegin/End()
> One final question/comment regarding Mercurial: when directories are moved or deleted (such as with cuda -> cusp naming), but the original contains generated files (*.html, *.d), the directory is not removed from the file system.
   Good question, this bugs me to. Maybe worth asking Mecurial?
>  could use "hg clean" to remove all of this, but that is a blunt instrument because it removes things I might want to keep (like example output and man pages for things I care about). Is there a way to automatically remove the now-meaningless directories? Also, what do people think about generating *.html somewhere outside the source tree?
   Can't you do this with LOC=/someotherplacewhere you are putting docs
> (It looks like clutter to me and then we have to use ack or give flags to grep when searching the tree.)
