[petsc-dev] worthless information
    Barry Smith
    bsmith at mcs.anl.gov
    Tue Aug 30 13:33:21 CDT 2011
On Aug 30, 2011, at 1:27 PM, Satish Balay wrote:
> On Tue, 30 Aug 2011, Barry Smith wrote:
>>>> Compilers:
>>>> C Compiler:         /home/balay/petsc-dev/arch-cuda-double/bin/mpicc
>>>>  It should also print the underlying compiler that is used by mpicc.
>>> Right now - configure.log is the location for details. [and wrt
>>> --download stuff - make.log also has the configure command which has
>>> the details]
>>> Sure - we don't have everything in summary printed by configure
>>   Well if room is so tight in the "summary printed by configure" then why do we waste room printing
>>   since that conveys no information. Why not take it out and then there will be room for actually providing useful information.
> There is verious levels of usefullness. Right now its says its using
> mpicc installed by user - instead of some sysmte mpicc or somthing
> else.
> C compiler: /home/balay/petsc-dev/arch-cuda-double/bin/mpicc
> Fortran compiler: fortran
> There is still some useful info here.
> Its just that it doesn't have the info you are currently looking for..
> Perhaps Matt can update configure to have this info detected in a
> useable format to be printed here.. [whats in configure.log is some
> verbose info - not suitable for summary]
   Exactly. Whenever it prints the mpicc/f90 etc it should also print in a simple form the compiler backing it up. For example icc or whatever. -show is not good because it prints too much crap
> Satish
