[petsc-dev] worthless information
Aron Ahmadia aron.ahmadia at kaust.edu.sa
Tue Aug 30 14:25:57 CDT 2011
Knowing what compiler 'script' is getting used by PETSc is extremely useful
for recreating the build as Matt suggested.  Many newbie PETSc errors I deal
with arise from mismatching system MPI libraries with a PETSc-installed MPI
and this is a quick way to detect the choice of MPI.
A
On Tue, Aug 30, 2011 at 9:33 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> On Aug 30, 2011, at 1:27 PM, Satish Balay wrote:
> > On Tue, 30 Aug 2011, Barry Smith wrote:
> >>>> Compilers:
> >>>> C Compiler:         /home/balay/petsc-dev/arch-cuda-double/bin/mpicc
> >>>>  It should also print the underlying compiler that is used by mpicc.
> >>> Right now - configure.log is the location for details. [and wrt
> >>> --download stuff - make.log also has the configure command which has
> >>> the details]
> >>> Sure - we don't have everything in summary printed by configure
> >>   Well if room is so tight in the "summary printed by configure" then
> why do we waste room printing
> >>   since that conveys no information. Why not take it out and then there
> will be room for actually providing useful information.
> > There is verious levels of usefullness. Right now its says its using
> > mpicc installed by user - instead of some sysmte mpicc or somthing
> > else.
> > C compiler: /home/balay/petsc-dev/arch-cuda-double/bin/mpicc
> > Fortran compiler: fortran
> > There is still some useful info here.
> > Its just that it doesn't have the info you are currently looking for..
> > Perhaps Matt can update configure to have this info detected in a
> > useable format to be printed here.. [whats in configure.log is some
> > verbose info - not suitable for summary]
>    Exactly. Whenever it prints the mpicc/f90 etc it should also print in a
> simple form the compiler backing it up. For example icc or whatever. -show
> is not good because it prints too much crap
> > Satish
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20110830/7bf86915/attachment.html>
