[petsc-dev] description and mansec in PetscHeaderCreate()
Matthew Knepley
knepley at gmail.com
Thu Aug 25 23:54:21 CDT 2011
On Fri, Aug 26, 2011 at 12:32 AM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
> I wanted (a) only one -help output per object and (b) more structured
> options for objects, so I added two fields to _p_PetscObject:
> char *description; /* long description of the object */
> char *mansec; /* manual section for more information about the object */
> These correspond to two new arguments to PetscHeaderCreate().
> Then I made a new function PetscObjectOptionsBegin(PetscObject) that
> handles printing only once (through a flag in _p_PetscObject) and fills out
> the correct description and man sections.
> I'm most of the way done with implementing this, but speak up if you think
> it's a bad idea.
Do we really need per object help? Shouldn't this be per class?
Matt
What most experimenters take for granted before they begin their experiments
is infinitely more interesting than any results to which their experiments
lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20110826/3fbad659/attachment.html>
