[petsc-dev] hg problem
Satish Balay
balay at mcs.anl.gov
Wed Aug 24 21:09:25 CDT 2011
On Wed, 24 Aug 2011, Satish Balay wrote:
> you were perhaps in a middle of a merge. To check that - you would do:
> hg parent
> Here 'hg status; hg diff' doesn't really help with figuring out things.
I should have said: When in the merge mode - 'hg status/diff' should
not be interpreted as 'my changes'. It usually correspoinds to the
remote changes that are being merged.
hg status/diff is always wrt 'parent'.
Explanation:
With the workflow "edit; commit; pull; merge; commit" - the following
happens:
1 edit: When you change files 'hg status/diff' would show your edits
wrt your start point. [aka parent]
2. commit: A new commit is made. This rev is now both the parent and
tip [of the working files].
[parent/tip]
changeset: 20045:4bf480f9a778
user: Mark F. Adams <mark.adams at columbia.edu>
3. pull: now you get new changes from the remote repo. The head of
these new changesets becomes the tip, but parent remains the same as
above. [Now you have 2 heads - tip, parent]
[tip]
changeset: 20041:10ecfa0551da
user: Lisandro Dalcin <dalcinl at gmail.com>
[parent]
3. merge: Now the changes from tip [which you pulled] get applied to
the working copy [i.e working copy now corresopnds to merging of your
changes with the remote changes]. And both heads are marked as parent
in this 'merge mode'.
[parent]
4. Now if you do 'hg status/diff' - it shows the changes in the
working files wrt the first parent. i.e changes wrt 20045. But since
20041 is already merged into working dir - this change [wrt 20045] is
visible in the status/diff.
5. commit: this commits the merge [that joins the 2 heads into 1].
This new merge commit is now both the parent and tip.
changeset: 20046:2f433672fa82
6. push: transmit all local commits to remote repo.
hope this clarifies the issue,
Satish
> You just follow hg's messages after each command is invoked
> hg pull
> hg merge
> [don't do hg status/diff now]
> hg commit
> hg push
> Satish
> On Wed, 24 Aug 2011, Mark F. Adams wrote:
> > I tried revert on this file (which I did not touch) iga.c but got a message to try 'hg revert help' ... which was no help.
> > So I just went ahead and committed the whole thing and and that cleared it up. I've appended the diffs, but as I said I've never touched this file. Hope I didn't clobber someones stuff,
> > Mark
> > diff -r 4bf480f9a778 src/dm/impls/iga/iga.c
> > --- a/src/dm/impls/iga/iga.c Wed Aug 24 17:08:17 2011 -0700
> > +++ b/src/dm/impls/iga/iga.c Wed Aug 24 17:43:52 2011 -0700
> > @@ -1555,24 +1555,22 @@
> > #define __FUNCT__ "CreateKnotVector"
> > PetscErrorCode CreateKnotVector(PetscInt N,PetscInt p,PetscInt C,PetscInt m, PetscReal *U,PetscReal U0,PetscReal Uf)
> > - PetscInt i,j;
> > + PetscInt i,j;
> > PetscReal dU;
> > - PetscInt k0;
> > PetscFunctionBegin;
> > - for(i=0;i<p+1;i++) /* open part */
> > + dU = (Uf-U0)/N;
> > + for(i=0;i<(N-1);i++) /* insert N-1 knots */
> > + for(j=0;j<(p-C);j++) /* p-C times */
> > + U[(p+1) + i*(p-C) + j] = U0 + (i+1)*dU;
> > + for(i=0;i<(p+1);i++) /* open part */
> > U[i] = U0;
> > U[m-i-1] = Uf;
> > - dU = (Uf-U0)/((PetscReal) N);
> > - k0 = p+1;
> > - for(i=0;i<(N-1);i++) /* insert N-1 knots */
> > - for(j=0;j<(p-C);j++) /* p-C+1 times */
> > - U[k0 + i*(p-C) + j] = U0+((PetscReal) (i+1))*dU;
> > PetscFunctionReturn(0);
> > @@ -1580,29 +1578,22 @@
> > #define __FUNCT__ "CreatePeriodicKnotVector"
> > PetscErrorCode CreatePeriodicKnotVector(PetscInt N,PetscInt p,PetscInt C,PetscInt m, PetscReal *U,PetscReal U0,PetscReal Uf)
> > - PetscInt i,j;
> > + PetscInt i,j;
> > PetscReal dU;
> > - PetscInt k0;
> > - PetscFunctionBegin; /* periodic part */
> > - U[p] = U0;
> > - U[m-p-1] = Uf;
> > + PetscFunctionBegin;
> > - k0 = p+1;
> > + dU = (Uf-U0)/N;
> > + for(i=0;i<(N+1);i++) /* insert N+1 knots */
> > + U[(C+1) + i*(p-C) + j] = U0 + i*dU;
> > + for(i=0;i<(C+1);i++) /* periodic part */
> > + U[i] = U0 - (Uf - U[(m-1-p)-(C+1)+i]);
> > + U[m-(C+1)+i] = Uf + (U[p+1+i] - U0);
> > - for(i=0;i<p;i++)
> > - U[i] = -U[m-p-1]+U[m-p-1-(p-i)];
> > - U[m-p+i] = U[m-p-1]+U[p+i+1];
> > On Aug 24, 2011, at 8:45 PM, Jed Brown wrote:
> > > On Wed, Aug 24, 2011 at 19:16, Mark F. Adams <mark.adams at columbia.edu> wrote:
> > > I'm stuck. I seem to have some file that I know nothing about:
> > > examples/tutorials> hg status -m
> > > M src/dm/impls/iga/iga.c
> > > that seems to be holding me up from doing just about anything with hg. I've tried reverting it with not luck.
> > > hg diff -- to see if there is anything you want to keep
> > > hg revert src/dm/impls/iga/iga.c -- to discard those changes
> > > hg update -C -- to discard any changes in the current working tree and update to the given revision (tip, by default)
> > > If you have a problem with these, paste the full output.
