[petsc-dev] KSP Viewer problem in petsc3.1
Gabriele Jost
gjost at tacc.utexas.edu
Thu Aug 25 10:57:33 CDT 2011
Hello!
I am running into a problem when using petsc 3.1 and SuperLU.
KSP Object:
type: preonly
maximum iterations=5000, initial guess is zero
tolerances: relative=1e-06, absolute=1e-50, divergence=10000
left preconditioning
using PRECONDITIONED norm type for convergence test
PC Object:
type: lu
LU: out-of-place factorization
tolerance for zero pivot 1e-12
matrix ordering: natural
factor fill ratio given 0, needed 0
Factored matrix follows:
Matrix Object:
type=mpiaij, rows=13608, cols=13608
package used to perform factorization: superlu_dist
total: nonzeros=0, allocated nonzeros=27216
SuperLU_DIST run parameters:
Process grid nprow 8 x npcol 8
Equilibrate matrix TRUE
Matrix input mode 1
Replace tiny pivots TRUE
Use iterative refinement FALSE
Processors in row 8 col partition 8
Row permutation LargeDiag
[59]PETSC ERROR: --------------------- Error Message ------------------------------------
[60]PETSC ERROR: Petsc Release Version 3.1.0, Patch 5, Mon Sep 27 11:51:54 CDT 2010
[62]PETSC ERROR: [53]PETSC ERROR: Unknown column permutation!
See docs/changes/index.html for recent updates.
I googled around and found that a similar problem had been reported to the Petsc folks before. The answer was as follows:
On Wed, 15 Dec 2010, Satish Balay wrote:
> Can you try the attached patch - and see if this goes away?
> patch -Np1 < superlu_dist.patch
Is the patch above included in the SLU that is part of the petsc 3.1 distribution? If not, could we get it?
Thanks so much in advance and best regards,
Gabriele
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20110825/14951ace/attachment.html>
