[petsc-dev] hg problem
Satish Balay
balay at mcs.anl.gov
Wed Aug 24 20:13:59 CDT 2011
you were perhaps in a middle of a merge. To check that - you would do:
hg parent
Here 'hg status; hg diff' doesn't really help with figuring out things.
You just follow hg's messages after each command is invoked
hg pull
hg merge
[don't do hg status/diff now]
hg commit
hg push
Satish
On Wed, 24 Aug 2011, Mark F. Adams wrote:
> I tried revert on this file (which I did not touch) iga.c but got a message to try 'hg revert help' ... which was no help.
> So I just went ahead and committed the whole thing and and that cleared it up. I've appended the diffs, but as I said I've never touched this file. Hope I didn't clobber someones stuff,
> Mark
> diff -r 4bf480f9a778 src/dm/impls/iga/iga.c
> --- a/src/dm/impls/iga/iga.c Wed Aug 24 17:08:17 2011 -0700
> +++ b/src/dm/impls/iga/iga.c Wed Aug 24 17:43:52 2011 -0700
> @@ -1555,24 +1555,22 @@
> #define __FUNCT__ "CreateKnotVector"
> PetscErrorCode CreateKnotVector(PetscInt N,PetscInt p,PetscInt C,PetscInt m, PetscReal *U,PetscReal U0,PetscReal Uf)
> - PetscInt i,j;
> + PetscInt i,j;
> PetscReal dU;
> - PetscInt k0;
> PetscFunctionBegin;
> - for(i=0;i<p+1;i++) /* open part */
> + dU = (Uf-U0)/N;
> + for(i=0;i<(N-1);i++) /* insert N-1 knots */
> + for(j=0;j<(p-C);j++) /* p-C times */
> + U[(p+1) + i*(p-C) + j] = U0 + (i+1)*dU;
> + for(i=0;i<(p+1);i++) /* open part */
> U[i] = U0;
> U[m-i-1] = Uf;
> - dU = (Uf-U0)/((PetscReal) N);
> - k0 = p+1;
> - for(i=0;i<(N-1);i++) /* insert N-1 knots */
> - for(j=0;j<(p-C);j++) /* p-C+1 times */
> - U[k0 + i*(p-C) + j] = U0+((PetscReal) (i+1))*dU;
> PetscFunctionReturn(0);
> @@ -1580,29 +1578,22 @@
> #define __FUNCT__ "CreatePeriodicKnotVector"
> PetscErrorCode CreatePeriodicKnotVector(PetscInt N,PetscInt p,PetscInt C,PetscInt m, PetscReal *U,PetscReal U0,PetscReal Uf)
> - PetscInt i,j;
> + PetscInt i,j;
> PetscReal dU;
> - PetscInt k0;
> - PetscFunctionBegin; /* periodic part */
> - U[p] = U0;
> - U[m-p-1] = Uf;
> + PetscFunctionBegin;
> - k0 = p+1;
> + dU = (Uf-U0)/N;
> + for(i=0;i<(N+1);i++) /* insert N+1 knots */
> + U[(C+1) + i*(p-C) + j] = U0 + i*dU;
> + for(i=0;i<(C+1);i++) /* periodic part */
> + U[i] = U0 - (Uf - U[(m-1-p)-(C+1)+i]);
> + U[m-(C+1)+i] = Uf + (U[p+1+i] - U0);
> - for(i=0;i<p;i++)
> - U[i] = -U[m-p-1]+U[m-p-1-(p-i)];
> - U[m-p+i] = U[m-p-1]+U[p+i+1];
> On Aug 24, 2011, at 8:45 PM, Jed Brown wrote:
> > On Wed, Aug 24, 2011 at 19:16, Mark F. Adams <mark.adams at columbia.edu> wrote:
> > I'm stuck. I seem to have some file that I know nothing about:
> > examples/tutorials> hg status -m
> > M src/dm/impls/iga/iga.c
> > that seems to be holding me up from doing just about anything with hg. I've tried reverting it with not luck.
> > hg diff -- to see if there is anything you want to keep
> > hg revert src/dm/impls/iga/iga.c -- to discard those changes
> > hg update -C -- to discard any changes in the current working tree and update to the given revision (tip, by default)
> > If you have a problem with these, paste the full output.
