[petsc-dev] printing the matrix name via -mat_view_info
    Barry Smith
    bsmith at mcs.anl.gov
    Wed Sep 29 14:33:12 CDT 2010
   Good idea. But why just for Matrices, why not for all objects?
   If no name is set do we use PetscObjectName() to generate one at that time or only print a name if it already has one (I lean toward that).
   I'll start on this.
   Barry
On Sep 29, 2010, at 2:28 PM, Shri wrote:
> Is there a way to print the matrix name so that -mat_view_info prints it out.
> Instead of
> Matrix Object:
>  type=mpiaij, rows=200, cols=200
>  total: nonzeros=40000, allocated nonzeros=40000
>  total number of mallocs used during MatSetVal
> it should print
> Matrix Object: <MATRIX_NAME>
> It'll be nice to have the matrix name printed out cause sometimes it gets confusing when there are a lot of matrices you are working with.
> Either the user can set a name and it could be printed out in mat_view_info or even better if in some way the variable name can be used directly.
> What do you think?
> Shri
