[petsc-dev] printing the matrix name via -mat_view_info
Shri
abhyshr at mcs.anl.gov
Wed Sep 29 14:28:46 CDT 2010
Is there a way to print the matrix name so that -mat_view_info prints it out.
Instead of
Matrix Object:
type=mpiaij, rows=200, cols=200
total: nonzeros=40000, allocated nonzeros=40000
total number of mallocs used during MatSetVal
it should print
Matrix Object: <MATRIX_NAME>
It'll be nice to have the matrix name printed out cause sometimes it gets confusing when there are a lot of matrices you are working with.
Either the user can set a name and it could be printed out in mat_view_info or even better if in some way the variable name can be used directly.
What do you think?
Shri
