[petsc-dev] printing the matrix name via -mat_view_info
abhyshr at mcs.anl.gov
Wed Sep 29 15:55:40 CDT 2010
----- "Barry Smith" <bsmith at mcs.anl.gov> wrote:
> Good idea. But why just for Matrices, why not for all objects?
> If no name is set do we use PetscObjectName() to generate one at
> that time
What does PetscObjectName() do??Generate a random name??
or only print a name if it already has one (I lean toward
> that).
> I'll start on this.
> Barry
> On Sep 29, 2010, at 2:28 PM, Shri wrote:
> > Is there a way to print the matrix name so that -mat_view_info
> prints it out.
> > Instead of
> > Matrix Object:
> > type=mpiaij, rows=200, cols=200
> > total: nonzeros=40000, allocated nonzeros=40000
> > total number of mallocs used during MatSetVal
> > it should print
> > Matrix Object: <MATRIX_NAME>
> > It'll be nice to have the matrix name printed out cause sometimes it
> gets confusing when there are a lot of matrices you are working with.
> > Either the user can set a name and it could be printed out in
> mat_view_info or even better if in some way the variable name can be
> used directly.
> > What do you think?
> > Shri
