[petsc-dev] Configure changes
    Satish Balay
    balay at mcs.anl.gov
    Tue Sep 28 11:54:44 CDT 2010
I still see these aswell..
satish
On Wed, 15 Sep 2010, Barry Smith wrote:
>   Matt,
>     I also get those ugly directories; can you please make them disappear.
>    Barry
> On Sep 15, 2010, at 10:31 AM, Lisandro Dalcin wrote:
> > On 15 September 2010 11:17, Satish Balay <balay at mcs.anl.gov> wrote:
> >> works for me now. thanks!
> > I've got a bunch of new directories in $PETSC_DIR after running
> > $PETSC_ARCH/conf/reconfigure-$PETSC_ARCH.py:
> >  drwxr-xr-x.  2 dalcinl users    4096 2010-09-15 11:47 config.compilerFlags
> >  drwxr-xr-x.  2 dalcinl users    4096 2010-09-15 11:47 config.compilers
> >  drwxr-xr-x.  2 dalcinl users    4096 2010-09-15 11:47 config.headers
> >  drwxr-xr-x.  2 dalcinl users    4096 2010-09-15 11:47 config.libraries
> >  drwxr-xr-x.  2 dalcinl users    4096 2010-09-15 11:47 config.setCompilers
> >> satish
> >> On Wed, 15 Sep 2010, Matthew Knepley wrote:
> >>> Pushed a fix.
> >>>   Matt
> >>> On Wed, Sep 15, 2010 at 8:31 AM, Satish Balay <balay at mcs.anl.gov> wrote:
> >>>> Thanks. Its much better now. However - I still see 4 dirs per run -
> >>>> instead of a single dir.
> >>>> asterix:/home/balay/tmp/petsc-dev>ls -ld /tmp/petsc*
> >>>> drwx------. 7 balay balay 4096 Sep 15 08:25 /tmp/petsc-3t39Wz/
> >>>> drwx------. 7 balay balay 4096 Sep 15 08:25 /tmp/petsc-atP6HX/
> >>>> drwx------. 7 balay balay 4096 Sep 15 08:25 /tmp/petsc-MoSphJ/
> >>>> drwx------. 7 balay balay 4096 Sep 15 08:25 /tmp/petsc-S3q8cO/
> >>>> Satish
> >>>>> I have reorganized the temp dir structure into what we wanted:
> >>>>>   framework has a top-level tmpDir (petsc-foo) per run
> >>>>>   each module has its own dir (petsc-foo/moduleName) below this
> >>>>>   the tmpDir is destryed by framework.cleanup()
> >>>>> and the Windows bug should be fixed.
> >>>>>    Matt
> > Lisandro Dalcin
> > CIMEC (INTEC/CONICET-UNL)
> > Predio CONICET-Santa Fe
> > Colectora RN 168 Km 472, Paraje El Pozo
> > Tel: +54-342-4511594 (ext 1011)
> > Tel/Fax: +54-342-4511169
