[petsc-dev] Configure changes
    Matthew Knepley
    knepley at gmail.com
    Tue Sep 28 22:53:26 CDT 2010
They should be gone. I pushed before I left, and checked my run.
   Matt
On Tue, Sep 28, 2010 at 4:54 PM, Satish Balay <balay at mcs.anl.gov> wrote:
> I still see these aswell..
> satish
> On Wed, 15 Sep 2010, Barry Smith wrote:
> >   Matt,
> >     I also get those ugly directories; can you please make them
> disappear.
> >    Barry
> > On Sep 15, 2010, at 10:31 AM, Lisandro Dalcin wrote:
> > > On 15 September 2010 11:17, Satish Balay <balay at mcs.anl.gov> wrote:
> > >> works for me now. thanks!
> > > I've got a bunch of new directories in $PETSC_DIR after running
> > > $PETSC_ARCH/conf/reconfigure-$PETSC_ARCH.py:
> > >  drwxr-xr-x.  2 dalcinl users    4096 2010-09-15 11:47
> config.compilerFlags
> > >  drwxr-xr-x.  2 dalcinl users    4096 2010-09-15 11:47 config.compilers
> > >  drwxr-xr-x.  2 dalcinl users    4096 2010-09-15 11:47 config.headers
> > >  drwxr-xr-x.  2 dalcinl users    4096 2010-09-15 11:47 config.libraries
> config.setCompilers
> > >> satish
> > >> On Wed, 15 Sep 2010, Matthew Knepley wrote:
> > >>> Pushed a fix.
> > >>>   Matt
> > >>> On Wed, Sep 15, 2010 at 8:31 AM, Satish Balay <balay at mcs.anl.gov>
> wrote:
> > >>>> Thanks. Its much better now. However - I still see 4 dirs per run -
> > >>>> instead of a single dir.
> > >>>> asterix:/home/balay/tmp/petsc-dev>ls -ld /tmp/petsc*
> > >>>> drwx------. 7 balay balay 4096 Sep 15 08:25 /tmp/petsc-3t39Wz/
> > >>>> drwx------. 7 balay balay 4096 Sep 15 08:25 /tmp/petsc-atP6HX/
> > >>>> drwx------. 7 balay balay 4096 Sep 15 08:25 /tmp/petsc-MoSphJ/
> > >>>> drwx------. 7 balay balay 4096 Sep 15 08:25 /tmp/petsc-S3q8cO/
> > >>>> Satish
> > >>>>> I have reorganized the temp dir structure into what we wanted:
> > >>>>>   framework has a top-level tmpDir (petsc-foo) per run
> > >>>>>   each module has its own dir (petsc-foo/moduleName) below this
> > >>>>>   the tmpDir is destryed by framework.cleanup()
> > >>>>> and the Windows bug should be fixed.
> > >>>>>    Matt
> > > Lisandro Dalcin
> > > CIMEC (INTEC/CONICET-UNL)
> > > Predio CONICET-Santa Fe
> > > Colectora RN 168 Km 472, Paraje El Pozo
> > > Tel: +54-342-4511594 (ext 1011)
> > > Tel/Fax: +54-342-4511169
What most experimenters take for granted before they begin their experiments
is infinitely more interesting than any results to which their experiments
lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20100929/422db08d/attachment.html>
