[petsc-dev] Configure changes
    Barry Smith
    bsmith at mcs.anl.gov
    Wed Sep 15 13:00:03 CDT 2010
  Matt,
    I also get those ugly directories; can you please make them disappear.
   Barry
On Sep 15, 2010, at 10:31 AM, Lisandro Dalcin wrote:
> On 15 September 2010 11:17, Satish Balay <balay at mcs.anl.gov> wrote:
>> works for me now. thanks!
> I've got a bunch of new directories in $PETSC_DIR after running
> $PETSC_ARCH/conf/reconfigure-$PETSC_ARCH.py:
>  drwxr-xr-x.  2 dalcinl users    4096 2010-09-15 11:47 config.compilerFlags
>  drwxr-xr-x.  2 dalcinl users    4096 2010-09-15 11:47 config.compilers
>  drwxr-xr-x.  2 dalcinl users    4096 2010-09-15 11:47 config.headers
>  drwxr-xr-x.  2 dalcinl users    4096 2010-09-15 11:47 config.libraries
>  drwxr-xr-x.  2 dalcinl users    4096 2010-09-15 11:47 config.setCompilers
>> satish
>> On Wed, 15 Sep 2010, Matthew Knepley wrote:
>>> Pushed a fix.
>>>   Matt
>>> On Wed, Sep 15, 2010 at 8:31 AM, Satish Balay <balay at mcs.anl.gov> wrote:
>>>> Thanks. Its much better now. However - I still see 4 dirs per run -
>>>> instead of a single dir.
>>>> asterix:/home/balay/tmp/petsc-dev>ls -ld /tmp/petsc*
>>>> drwx------. 7 balay balay 4096 Sep 15 08:25 /tmp/petsc-3t39Wz/
>>>> drwx------. 7 balay balay 4096 Sep 15 08:25 /tmp/petsc-atP6HX/
>>>> drwx------. 7 balay balay 4096 Sep 15 08:25 /tmp/petsc-MoSphJ/
>>>> drwx------. 7 balay balay 4096 Sep 15 08:25 /tmp/petsc-S3q8cO/
>>>> Satish
>>>>> I have reorganized the temp dir structure into what we wanted:
>>>>>   framework has a top-level tmpDir (petsc-foo) per run
>>>>>   each module has its own dir (petsc-foo/moduleName) below this
>>>>>   the tmpDir is destryed by framework.cleanup()
>>>>> and the Windows bug should be fixed.
>>>>>    Matt
> Lisandro Dalcin
> CIMEC (INTEC/CONICET-UNL)
> Predio CONICET-Santa Fe
> Colectora RN 168 Km 472, Paraje El Pozo
> Tel: +54-342-4511594 (ext 1011)
> Tel/Fax: +54-342-4511169
