[petsc-dev] backport setup.py to release-3.1
    Aron Ahmadia
    aron.ahmadia at kaust.edu.sa
    Thu Sep 16 17:43:18 CDT 2010
Lisandro,
I think this is going to depend on what your release cycle looks like over
the next year in comparison with the PETSc team.  If the two teams can
coordinate releases, I think it is better to be working against PETSc
releases.
A
On Thu, Sep 16, 2010 at 6:18 PM, Lisandro Dalcin <dalcinl at gmail.com> wrote:
> I've managed to backport setup.py to release-3.1. It does not require
> any change to BuildSystem or install.py, as I'm simply using
> os.system() to spawn configure, make and install. Matt agreed that we
> could add setup.py to release-3.1 (as it would not break anything),
> and then get the beast working right now. As a plus, this could also
> be done with SLEPc and slepc4py.
> Other far less intrusive alternative would be to just upload PETSc
> (and SLEPc) tarballs to PyPI containing my setup.py. Then nothing have
> to be done with current PETSc and SLEPc releases. What do you think?
> Lisandro Dalcin
> CIMEC (INTEC/CONICET-UNL)
> Predio CONICET-Santa Fe
> Colectora RN 168 Km 472, Paraje El Pozo
> Tel: +54-342-4511594 (ext 1011)
> Tel/Fax: +54-342-4511169
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20100916/5069b17f/attachment.html>
