[petsc-dev] Configure changes
    Lisandro Dalcin
    dalcinl at gmail.com
    Wed Sep 15 10:31:06 CDT 2010
On 15 September 2010 11:17, Satish Balay <balay at mcs.anl.gov> wrote:
> works for me now. thanks!
I've got a bunch of new directories in $PETSC_DIR after running
$PETSC_ARCH/conf/reconfigure-$PETSC_ARCH.py:
  drwxr-xr-x.  2 dalcinl users    4096 2010-09-15 11:47 config.compilerFlags
  drwxr-xr-x.  2 dalcinl users    4096 2010-09-15 11:47 config.compilers
  drwxr-xr-x.  2 dalcinl users    4096 2010-09-15 11:47 config.headers
  drwxr-xr-x.  2 dalcinl users    4096 2010-09-15 11:47 config.libraries
  drwxr-xr-x.  2 dalcinl users    4096 2010-09-15 11:47 config.setCompilers
> satish
> On Wed, 15 Sep 2010, Matthew Knepley wrote:
>> Pushed a fix.
>>   Matt
>> On Wed, Sep 15, 2010 at 8:31 AM, Satish Balay <balay at mcs.anl.gov> wrote:
>> > Thanks. Its much better now. However - I still see 4 dirs per run -
>> > instead of a single dir.
>> > asterix:/home/balay/tmp/petsc-dev>ls -ld /tmp/petsc*
>> > drwx------. 7 balay balay 4096 Sep 15 08:25 /tmp/petsc-3t39Wz/
>> > drwx------. 7 balay balay 4096 Sep 15 08:25 /tmp/petsc-atP6HX/
>> > drwx------. 7 balay balay 4096 Sep 15 08:25 /tmp/petsc-MoSphJ/
>> > drwx------. 7 balay balay 4096 Sep 15 08:25 /tmp/petsc-S3q8cO/
>> > Satish
>> > > I have reorganized the temp dir structure into what we wanted:
>> > >   framework has a top-level tmpDir (petsc-foo) per run
>> > >   each module has its own dir (petsc-foo/moduleName) below this
>> > >   the tmpDir is destryed by framework.cleanup()
>> > > and the Windows bug should be fixed.
>> > >    Matt
Lisandro Dalcin
CIMEC (INTEC/CONICET-UNL)
Predio CONICET-Santa Fe
Colectora RN 168 Km 472, Paraje El Pozo
Tel: +54-342-4511594 (ext 1011)
Tel/Fax: +54-342-4511169
