[petsc-dev] Configure changes
    Satish Balay
    balay at mcs.anl.gov
    Wed Sep 15 09:17:02 CDT 2010
works for me now. thanks!
satish
On Wed, 15 Sep 2010, Matthew Knepley wrote:
> Pushed a fix.
>   Matt
> On Wed, Sep 15, 2010 at 8:31 AM, Satish Balay <balay at mcs.anl.gov> wrote:
> > Thanks. Its much better now. However - I still see 4 dirs per run -
> > instead of a single dir.
> > asterix:/home/balay/tmp/petsc-dev>ls -ld /tmp/petsc*
> > drwx------. 7 balay balay 4096 Sep 15 08:25 /tmp/petsc-3t39Wz/
> > drwx------. 7 balay balay 4096 Sep 15 08:25 /tmp/petsc-atP6HX/
> > drwx------. 7 balay balay 4096 Sep 15 08:25 /tmp/petsc-MoSphJ/
> > drwx------. 7 balay balay 4096 Sep 15 08:25 /tmp/petsc-S3q8cO/
> > Satish
> > > I have reorganized the temp dir structure into what we wanted:
> > >   framework has a top-level tmpDir (petsc-foo) per run
> > >   each module has its own dir (petsc-foo/moduleName) below this
> > >   the tmpDir is destryed by framework.cleanup()
> > > and the Windows bug should be fixed.
> > >    Matt
