[petsc-dev] Configure changes
    Matthew Knepley
    knepley at gmail.com
    Wed Sep 15 09:00:44 CDT 2010
Pushed a fix.
  Matt
On Wed, Sep 15, 2010 at 8:31 AM, Satish Balay <balay at mcs.anl.gov> wrote:
> Thanks. Its much better now. However - I still see 4 dirs per run -
> instead of a single dir.
> asterix:/home/balay/tmp/petsc-dev>ls -ld /tmp/petsc*
> drwx------. 7 balay balay 4096 Sep 15 08:25 /tmp/petsc-3t39Wz/
> drwx------. 7 balay balay 4096 Sep 15 08:25 /tmp/petsc-atP6HX/
> drwx------. 7 balay balay 4096 Sep 15 08:25 /tmp/petsc-MoSphJ/
> drwx------. 7 balay balay 4096 Sep 15 08:25 /tmp/petsc-S3q8cO/
> Satish
> On Wed, 15 Sep 2010, Matthew Knepley wrote:
> > I have reorganized the temp dir structure into what we wanted:
> >   framework has a top-level tmpDir (petsc-foo) per run
> >   each module has its own dir (petsc-foo/moduleName) below this
> >   the tmpDir is destryed by framework.cleanup()
> > and the Windows bug should be fixed.
> >    Matt
What most experimenters take for granted before they begin their experiments
is infinitely more interesting than any results to which their experiments
lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20100915/fa3fca1c/attachment.html>
