[petsc-dev] python version creep
    Matthew Knepley
    knepley at gmail.com
    Thu Sep  2 04:24:15 CDT 2010
Fixed.
  MAtt
On Wed, Sep 1, 2010 at 4:01 PM, Leo van Kampenhout <lvankampenhout at gmail.com
> wrote:
> I'm getting similar errors from the configure script, as of today. See
> below.
> Leo
>              Configuring PETSc to compile on your
> system
> Traceback (most recent call last):
>   File "./configure", line 351, in <module>
>     petsc_configure([])
>   File "./configure", line 261, in petsc_configure
>     import config.base
>   File
> "/net/users/csg/csg4035/install/petsc-dev/config/BuildSystem/config/base.py",
> line 60, in <module>
>     import script
>   File
> "/net/users/csg/csg4035/install/petsc-dev/config/BuildSystem/script.py",
> line 22, in <module>
>     import nargs
>   File
> "/net/users/csg/csg4035/install/petsc-dev/config/BuildSystem/nargs.py", line
> 19, in <module>
>     class Arg(object):
>   File
> 53, in Arg
>     @deprecated.setter
> AttributeError: 'property' object has no attribute 'setter'
> 2010/9/1 Barry Smith <bsmith at mcs.anl.gov>
>> (view as text)<http://www.geodynamics.org:8009/PETSc%20dev%20darwin%2010.4%20single%20nosched%20binbot/builds/89/step-shell_2/0/text>
>> ./config/configure.py --with-mpi-dir=/Users/buildbot/install/darwin_10.4_single_nosched_binbot --with-debugging=no --with-fortran=no --download-boost=1 --with-sieve=1 --with-clanguage=C++ --with-mpi=1 --with-boost=1 --with-chaco=1 --download-chaco=1 --with-x=0 --with-shared-libraries=1 --CXXFLAGS=-DNEW_SECTION
>>  in dir /Users/buildbot/slave/build/darwin_10.4_single_nosched_binbot/PETSc/dev/binaries-89 (timeout 3600 secs)
>>  watching logfiles {'configure.log': 'configure.log'}
>>  argv: ['./config/configure.py', '--with-mpi-dir=/Users/buildbot/install/darwin_10.4_single_nosched_binbot', '--with-debugging=no', '--with-fortran=no', '--download-boost=1', '--with-sieve=1', '--with-clanguage=C++', '--with-mpi=1', '--with-boost=1', '--with-chaco=1', '--download-chaco=1', '--with-x=0', '--with-shared-libraries=1', '--CXXFLAGS=-DNEW_SECTION']
>>  environment: {'CC': 'mpicc', 'PYTHONPATH': '/Users/buildbot/install/darwin_10.4_single_nosched_binbot/lib/python2.3/site-packages:/Users/buildbot/lib/python2.3/site-packages', 'DYLD_LIBRARY_PATH': '/Users/buildbot/install/darwin_10.4_single_nosched_binbot/lib:/Users/buildbot/install/darwin_10.4_single_nosched_binbot/opt/petsc-dev/darwin8.11.1-cxx-opt/lib', 'PYTHON': 'python2.3', 'WORKDIR': '/Users/buildbot/slave/build/darwin_10.4_single_nosched_binbot/PETSc/dev/binaries-89', 'USER': 'buildbot', 'HOME': '/Users/buildbot', 'PREFIX': '/Users/buildbot/install/darwin_10.4_single_nosched_binbot', 'PATH': '/Users/buildbot/install/darwin_10.4_single_nosched_binbot/bin:/Users/buildbot/bin:/bin:/sbin:/usr/bin:/usr/sbin:/usr/local/bin:/usr/texbin', 'F77': 'mpif77', '_': '/Users/buildbot/bin/buildbot', 'TERM': 'xterm-color', 'SHELL': '/bin/bash', 'SHLVL': '1', 'PETSC_ARCH': 'darwin8.11.1-cxx-opt', '__CF_USER_TEXT_ENCODING': '0x1F9:0:0', 'CXX': 'mpicxx', 'PWD': '/Users/buildbot', 'FC': 'mpif90', 'PETSC_DIR': '/Users/buildbot/slave/build/darwin_10.4_single_nosched_binbot/PETSc/dev/binaries-89', 'HDF5_HOME': '/Users/buildbot/install/darwin_10.4_single_nosched_binbot'}===============================================================================
>>              Configuring PETSc to compile on your system
>>   File "./config/configure.py", line 351, in ?
>>     petsc_configure([])
>>   File "./config/configure.py", line 261, in petsc_configure
>>     import config.base
>>   File "/Users/buildbot/slave/build/darwin_10.4_single_nosched_binbot/PETSc/dev/binaries-89/config/BuildSystem/config/base.py", line 60, in ?
>>     import script
>>   File "/Users/buildbot/slave/build/darwin_10.4_single_nosched_binbot/PETSc/dev/binaries-89/config/BuildSystem/script.py", line 22, in ?
>>     import nargs
>>   File "/Users/buildbot/slave/build/darwin_10.4_single_nosched_binbot/PETSc/dev/binaries-89/config/BuildSystem/nargs.py", line 51
>>     @property
>> SyntaxError: invalid syntaxprogram finished with exit code 1
What most experimenters take for granted before they begin their experiments
is infinitely more interesting than any results to which their experiments
lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20100902/1ecf1792/attachment.html>
