[petsc-dev] [Fortran] MatLoad() error: MatLoad is not supported for type: mpiaij!
Leo van Kampenhout
lvankampenhout at gmail.com
Wed Sep 1 08:55:03 CDT 2010
Hi all,
I'm having trouble with MatLoad on Petsc-Dev. Not sure if this problem also
exists in the main PETSc 3.1 since my code won't compile on that.
The problematic calls are as follows:
call PetscViewerBinaryOpen(PETSC_COMM_WORLD,file2,
& FILE_MODE_READ,fd,ierr)
call DAGetMatrix(da,MATMPIAIJ,A,ierr)
call MatLoad(A,fd,ierr)
which supposedly will load a matrix A which is stored by the following
commands:
& FILE_MODE_WRITE,fd,ierr)
call MatView(A,fd,ierr)
by another program (on a single core). The MatLoad() does work perfectly on
a single core, however two or more cores make the program crash with the
following error (see below)
The programcall is
mpirun -n 2 ./main
Is something broken with Petsc or do I need to set some extra parameters?
Thanks in advance,
Leo van Kampenhout
PS. I'm using a build from last friday, since when I updated petsc-dev today
using Mercurial I couldnt get it to configure or compile :S (which is
another subject)
[0]PETSC ERROR: --------------------- Error Message
[0]PETSC ERROR: No support for this operation for this object type!
[0]PETSC ERROR: MatLoad is not supported for type: mpiaij!
[0]PETSC ERROR:
[0]PETSC ERROR: Petsc Development HG revision:
84fec3ca75412473b06251029b58f2a68f1334f3 HG Date: Fri Aug 27 07:06:08 2010
+0200
[0]PETSC ERROR: See docs/changes/index.html for recent updates.
[0]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
[0]PETSC ERROR: See docs/index.html for manual pages.
[0]PETSC ERROR:
[0]PETSC ERROR: ./main on a arch-linu named wingtip72 by csg4035 Wed Sep 1
15:52:11 2010
[0]PETSC ERROR: Libraries linked from
/net/users/csg/csg4035/install/petsc-dev/arch-linux-gnu-c-debug/lib
[0]PETSC ERROR: Configure run at Fri Aug 27 08:37:32 2010
[0]PETSC ERROR: Configure options
[0]PETSC ERROR:
[0]PETSC ERROR: MatLoad() line 843 in src/mat/interface/matrix.c
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20100901/9d4f6a41/attachment.html>
