[petsc-dev] python version creep
    Leo van Kampenhout
    lvankampenhout at gmail.com
    Wed Sep  1 09:01:56 CDT 2010
I'm getting similar errors from the configure script, as of today. See
below.
Leo
             Configuring PETSc to compile on your
system
Traceback (most recent call last):
  File "./configure", line 351, in <module>
    petsc_configure([])
  File "./configure", line 261, in petsc_configure
    import config.base
  File
"/net/users/csg/csg4035/install/petsc-dev/config/BuildSystem/config/base.py",
line 60, in <module>
    import script
  File
"/net/users/csg/csg4035/install/petsc-dev/config/BuildSystem/script.py",
line 22, in <module>
    import nargs
  File
"/net/users/csg/csg4035/install/petsc-dev/config/BuildSystem/nargs.py", line
19, in <module>
    class Arg(object):
  File
53, in Arg
    @deprecated.setter
AttributeError: 'property' object has no attribute 'setter'
2010/9/1 Barry Smith <bsmith at mcs.anl.gov>
> (view as text)<http://www.geodynamics.org:8009/PETSc%20dev%20darwin%2010.4%20single%20nosched%20binbot/builds/89/step-shell_2/0/text>
> ./config/configure.py --with-mpi-dir=/Users/buildbot/install/darwin_10.4_single_nosched_binbot --with-debugging=no --with-fortran=no --download-boost=1 --with-sieve=1 --with-clanguage=C++ --with-mpi=1 --with-boost=1 --with-chaco=1 --download-chaco=1 --with-x=0 --with-shared-libraries=1 --CXXFLAGS=-DNEW_SECTION
>  in dir /Users/buildbot/slave/build/darwin_10.4_single_nosched_binbot/PETSc/dev/binaries-89 (timeout 3600 secs)
>  watching logfiles {'configure.log': 'configure.log'}
>  argv: ['./config/configure.py', '--with-mpi-dir=/Users/buildbot/install/darwin_10.4_single_nosched_binbot', '--with-debugging=no', '--with-fortran=no', '--download-boost=1', '--with-sieve=1', '--with-clanguage=C++', '--with-mpi=1', '--with-boost=1', '--with-chaco=1', '--download-chaco=1', '--with-x=0', '--with-shared-libraries=1', '--CXXFLAGS=-DNEW_SECTION']
>  environment: {'CC': 'mpicc', 'PYTHONPATH': '/Users/buildbot/install/darwin_10.4_single_nosched_binbot/lib/python2.3/site-packages:/Users/buildbot/lib/python2.3/site-packages', 'DYLD_LIBRARY_PATH': '/Users/buildbot/install/darwin_10.4_single_nosched_binbot/lib:/Users/buildbot/install/darwin_10.4_single_nosched_binbot/opt/petsc-dev/darwin8.11.1-cxx-opt/lib', 'PYTHON': 'python2.3', 'WORKDIR': '/Users/buildbot/slave/build/darwin_10.4_single_nosched_binbot/PETSc/dev/binaries-89', 'USER': 'buildbot', 'HOME': '/Users/buildbot', 'PREFIX': '/Users/buildbot/install/darwin_10.4_single_nosched_binbot', 'PATH': '/Users/buildbot/install/darwin_10.4_single_nosched_binbot/bin:/Users/buildbot/bin:/bin:/sbin:/usr/bin:/usr/sbin:/usr/local/bin:/usr/texbin', 'F77': 'mpif77', '_': '/Users/buildbot/bin/buildbot', 'TERM': 'xterm-color', 'SHELL': '/bin/bash', 'SHLVL': '1', 'PETSC_ARCH': 'darwin8.11.1-cxx-opt', '__CF_USER_TEXT_ENCODING': '0x1F9:0:0', 'CXX': 'mpicxx', 'PWD': '/Users/buildbot', 'FC': 'mpif90', 'PETSC_DIR': '/Users/buildbot/slave/build/darwin_10.4_single_nosched_binbot/PETSc/dev/binaries-89', 'HDF5_HOME': '/Users/buildbot/install/darwin_10.4_single_nosched_binbot'}===============================================================================
>              Configuring PETSc to compile on your system
>   File "./config/configure.py", line 351, in ?
>     petsc_configure([])
>   File "./config/configure.py", line 261, in petsc_configure
>     import config.base
>   File "/Users/buildbot/slave/build/darwin_10.4_single_nosched_binbot/PETSc/dev/binaries-89/config/BuildSystem/config/base.py", line 60, in ?
>     import script
>   File "/Users/buildbot/slave/build/darwin_10.4_single_nosched_binbot/PETSc/dev/binaries-89/config/BuildSystem/script.py", line 22, in ?
>     import nargs
>   File "/Users/buildbot/slave/build/darwin_10.4_single_nosched_binbot/PETSc/dev/binaries-89/config/BuildSystem/nargs.py", line 51
>     @property
> SyntaxError: invalid syntaxprogram finished with exit code 1
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20100901/289c0f84/attachment.html>
