[petsc-dev] python version creep
    Barry Smith
    bsmith at mcs.anl.gov
    Wed Sep  1 08:12:37 CDT 2010
(view as text)
./config/configure.py --with-mpi-dir=/Users/buildbot/install/darwin_10.4_single_nosched_binbot --with-debugging=no --with-fortran=no --download-boost=1 --with-sieve=1 --with-clanguage=C++ --with-mpi=1 --with-boost=1 --with-chaco=1 --download-chaco=1 --with-x=0 --with-shared-libraries=1 --CXXFLAGS=-DNEW_SECTION
 in dir /Users/buildbot/slave/build/darwin_10.4_single_nosched_binbot/PETSc/dev/binaries-89 (timeout 3600 secs)
 watching logfiles {'configure.log': 'configure.log'}
 argv: ['./config/configure.py', '--with-mpi-dir=/Users/buildbot/install/darwin_10.4_single_nosched_binbot', '--with-debugging=no', '--with-fortran=no', '--download-boost=1', '--with-sieve=1', '--with-clanguage=C++', '--with-mpi=1', '--with-boost=1', '--with-chaco=1', '--download-chaco=1', '--with-x=0', '--with-shared-libraries=1', '--CXXFLAGS=-DNEW_SECTION']
 environment: {'CC': 'mpicc', 'PYTHONPATH': '/Users/buildbot/install/darwin_10.4_single_nosched_binbot/lib/python2.3/site-packages:/Users/buildbot/lib/python2.3/site-packages', 'DYLD_LIBRARY_PATH': '/Users/buildbot/install/darwin_10.4_single_nosched_binbot/lib:/Users/buildbot/install/darwin_10.4_single_nosched_binbot/opt/petsc-dev/darwin8.11.1-cxx-opt/lib', 'PYTHON': 'python2.3', 'WORKDIR': '/Users/buildbot/slave/build/darwin_10.4_single_nosched_binbot/PETSc/dev/binaries-89', 'USER': 'buildbot', 'HOME': '/Users/buildbot', 'PREFIX': '/Users/buildbot/install/darwin_10.4_single_nosched_binbot', 'PATH': '/Users/buildbot/install/darwin_10.4_single_nosched_binbot/bin:/Users/buildbot/bin:/bin:/sbin:/usr/bin:/usr/sbin:/usr/local/bin:/usr/texbin', 'F77': 'mpif77', '_': '/Users/buildbot/bin/buildbot', 'TERM': 'xterm-color', 'SHELL': '/bin/bash', 'SHLVL': '1', 'PETSC_ARCH': 'darwin8.11.1-cxx-opt', '__CF_USER_TEXT_ENCODING': '0x1F9:0:0', 'CXX': 'mpicxx', 'PWD': '/Users/buildbot', 'FC': 'mpif90', 'PETSC_DIR': '/Users/buildbot/slave/build/darwin_10.4_single_nosched_binbot/PETSc/dev/binaries-89', 'HDF5_HOME': '/Users/buildbot/install/darwin_10.4_single_nosched_binbot'}
             Configuring PETSc to compile on your system
Traceback (most recent call last):
  File "./config/configure.py", line 351, in ?
    petsc_configure([])
  File "./config/configure.py", line 261, in petsc_configure
    import config.base
  File "/Users/buildbot/slave/build/darwin_10.4_single_nosched_binbot/PETSc/dev/binaries-89/config/BuildSystem/config/base.py", line 60, in ?
    import script
  File "/Users/buildbot/slave/build/darwin_10.4_single_nosched_binbot/PETSc/dev/binaries-89/config/BuildSystem/script.py", line 22, in ?
    import nargs
  File "/Users/buildbot/slave/build/darwin_10.4_single_nosched_binbot/PETSc/dev/binaries-89/config/BuildSystem/nargs.py", line 51
    @property
SyntaxError: invalid syntax
program finished with exit code 1
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20100901/69103f45/attachment.html>
