[petsc-dev] BuildSystem update
Satish Balay
balay at mcs.anl.gov
Fri Oct 15 21:29:09 CDT 2010
pushed a fix for now. However I'm not sure if the following is appropriate:
> --download-netcdf-version=<string>
For one - its not a uniform option across all packages. And secondly
we have --download-packagename=URL working now.
Satish
On Fri, 15 Oct 2010, Satish Balay wrote:
> Dmitry,
> Your push breaks regular builds..
> asterix:/home/balay/tmp/petsc-dev>./config/examples/asterix/asterix64.py
> Configuring PETSc to compile on your system
> TESTING: alternateConfigureLibrary from PETSc.packages.hdf5(config/BuildSystem/config/package.py:459) Please enter value for download-netcdf:
> asterix:/home/balay/tmp/petsc-dev>./configure --help |grep netcdf
> --with-netcdf=<bool>
> --with-netcdf-dir=<dir>
> --with-netcdf-include=<dir>
> --with-netcdf-lib=<libraries: e.g. [/Users/..../libnetcdf.a,...]>
> --download-netcdf-shared=<bool>
> There is no download-netcdf option - but a new --download-netcdf-version?
> Satish
> On Fri, 15 Oct 2010, Dmitry Karpeev wrote:
> > I've added GNUPackage(config.package.Package), which is supposed to
> > simplify writing configure modules
> > for "GNU packages" (i.e., those that are installed using the
> > "configure; make; make install" paradigm).
> > NetCDF.py has been expanded a bit to allow for a download and derives
> > from GNUPackage now.
> > Bugs are likely, of course, so if anybody has any trouble configuring
> > with NetCDF, let me know and I'll take
> > care of it.
> > Thanks.
> > Dmitry.
