[petsc-dev] BuildSystem update
Dmitry Karpeev
karpeev at mcs.anl.gov
Fri Oct 15 23:13:25 CDT 2010
Okay, I'll look into it.
Thanks for catching it.
Dmitry.
On Fri, Oct 15, 2010 at 9:29 PM, Satish Balay <balay at mcs.anl.gov> wrote:
> pushed a fix for now. However I'm not sure if the following is appropriate:
>> --download-netcdf-version=<string>
> For one - its not a uniform option across all packages. And secondly
> we have --download-packagename=URL working now.
> Satish
> On Fri, 15 Oct 2010, Satish Balay wrote:
>> Dmitry,
>> Your push breaks regular builds..
>> asterix:/home/balay/tmp/petsc-dev>./config/examples/asterix/asterix64.py
>> Configuring PETSc to compile on your system
>> TESTING: alternateConfigureLibrary from PETSc.packages.hdf5(config/BuildSystem/config/package.py:459) Please enter value for download-netcdf:
>> asterix:/home/balay/tmp/petsc-dev>./configure --help |grep netcdf
>> --with-netcdf=<bool>
>> --with-netcdf-dir=<dir>
>> --with-netcdf-include=<dir>
>> --with-netcdf-lib=<libraries: e.g. [/Users/..../libnetcdf.a,...]>
>> --download-netcdf-shared=<bool>
>> There is no download-netcdf option - but a new --download-netcdf-version?
>> Satish
>> On Fri, 15 Oct 2010, Dmitry Karpeev wrote:
>> > I've added GNUPackage(config.package.Package), which is supposed to
>> > simplify writing configure modules
>> > for "GNU packages" (i.e., those that are installed using the
>> > "configure; make; make install" paradigm).
>> > NetCDF.py has been expanded a bit to allow for a download and derives
>> > from GNUPackage now.
>> > Bugs are likely, of course, so if anybody has any trouble configuring
>> > with NetCDF, let me know and I'll take
>> > care of it.
>> > Thanks.
>> > Dmitry.
