[petsc-dev] Could generatefortranstubs.py be lazier about modification times?
    Jed Brown
    jed at 59A2.org
    Tue Oct  5 11:34:35 CDT 2010
On Tue, Oct 5, 2010 at 18:20, Barry Smith <bsmith at mcs.anl.gov> wrote:
> Do you want a configure flag to turn off building them? If so is there a
> particular reason (including they are too hard to build?)?
I use the CMake build which builds them just fine, but I have a bunch of
PETSC_ARCHes, many of which use external packages that require a Fortran
compiler, but I almost never call PETSc from Fortran (only to debug problems
that people send me), so I'd rather not build the Fortran interface at all
for most values of PETSC_ARCH.
Jed
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20101005/e7d1e377/attachment.html>
