[petsc-dev] Could generatefortranstubs.py be lazier about	modification times?
    Barry Smith
    bsmith at mcs.anl.gov
    Tue Oct  5 11:20:48 CDT 2010
On Oct 5, 2010, at 11:12 AM, Jed Brown wrote:
> On Tue, Oct 5, 2010 at 18:08, Matthew Knepley <knepley at gmail.com> wrote:
> It does not do Fortran modules correctly because right now I cannot handle that level
> of wrongness.
> Can I provide a Fortran compiler (needed to build third-party packages), but disable building of Fortran modules?
> Jed
   I don't immedately see that. It looks like (using the regular make system) that Fortran modules are built if PETSC_USING_F90 is set and that is set whenever BuildSystem decides that it is using a Fortran 90 compiler.
   Do you want a configure flag to turn off building them? If so is there a particular reason (including they are too hard to build?)?
   Barry
