[petsc-dev] cmake issue
Lisandro Dalcin
dalcinl at gmail.com
Mon Oct 4 11:39:20 CDT 2010
On 4 October 2010 10:51, Jed Brown <five9a2 at gmail.com> wrote:
> On Mon, Oct 4, 2010 at 14:21, Lisandro Dalcin <dalcinl at gmail.com> wrote:
>> Jed, I had a file src/mat/impls/schur/ftn-auto/schurmf.c around
>> coming from old builds, I did not noticed it until now because of
>> hgignore . Trying to build with cmake failed because it tried to
>> compile that outdated file. Not a big deal, but I'm wondering if it
>> would be easy to fix?
> I have CMake automatically picking up the files in ftn-auto
> directories when Fortran is enabled (note that the makefiles in
> ftn-auto directories are also auto-generated). If it was just a stale
> file in the ftn-auto directory, the next time you ran configure (or
> make allfortranstubs), it would be removed. The problem here is that
> the whole impls/schur directory disappeared (2 years ago) when
> MatSchur was moved to KSP where it belongs. Just delete this ancient
> directory and reconfigure (or run config/cmakegen.py) and it should
> work. Let me know if you have any problem with this.
> Jed
Well, from 2 years ago up to now, I've reconfigured many times. It
seems the ftn-auto directory was not automatically removed.
Lisandro Dalcin
CIMEC (INTEC/CONICET-UNL)
Predio CONICET-Santa Fe
Colectora RN 168 Km 472, Paraje El Pozo
Tel: +54-342-4511594 (ext 1011)
Tel/Fax: +54-342-4511169
