[petsc-dev] reminder never use #include "mylocalinclude.h" in	PETSc source
    Matthew Knepley
    knepley at gmail.com
    Tue May  4 12:22:10 CDT 2010
On Tue, May 4, 2010 at 11:51 AM, Jed Brown <jed at 59a2.org> wrote:
> On Tue, 4 May 2010 11:37:14 -0500, Matthew Knepley <knepley at gmail.com>
> wrote:
> > I see. Yes, it currently uses the makefile organization. This is the
> > kind of metadata that Barry would like in a DB rather than in
> > makefiles.
> It would be easy to convert between being spread out in the makefiles
> and being held in some central location.  For instance, something like
> builder.py, run at the end of configuration time, could instead of
> building the project, write a single tupfile [1] for all of PETSc, and
> then we could rejoice with fast correct builds, even after
> reconfiguring.
> I think the metadata itself belongs with the implementations (more or
> less where it is currently) unless we are actually working with an
> image-based system (which does not look likely in the near future).
It looks like tup only has a Linux daemon, so it would run the same as make
everywhere else. That does not seem like a strong enough case to use it. Why
not just write the same thing in portable Python? We do need to run
everywhere.
   Matt
> Jed
> [1] For those who not in the know: http://gittup.org/tup/make_vs_tup.html
What most experimenters take for granted before they begin their experiments
is infinitely more interesting than any results to which their experiments
lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20100504/70fac1d7/attachment.html>
