[petsc-dev] reminder never use #include "mylocalinclude.h" in PETSc source
Matthew Knepley
knepley at gmail.com
Mon May 3 07:59:42 CDT 2010
I had the same understanding as Jed. What was the problem which prompted the
fix?
Matt
On Mon, May 3, 2010 at 5:41 AM, Jed Brown <jed at 59a2.org> wrote:
> On Sun, 2 May 2010 19:17:51 -0700, Barry Smith <bsmith at mcs.anl.gov> wrote:
> > Reminder, don't use
> > in the PETSc source, you should always make it relative the PETSC_DIR/
> > include directory such as
> > #include "../src/something/hereiman/mylocalinclude.h"
> I'm confused. The standard doesn't say anything about the relative
> meaning of <file.h> and "file.h", just that each involve an
> implementation-defined search, and if the search for "file.h" fails,
> then it should be searched for as if it had been <file.h>. But every
> compiler I'm aware of follows the POSIX standard (quoting from the
> description of -I):
> Change the algorithm for searching for headers whose names are not
> absolute pathnames to look in the directory named by the directory
> pathname before looking in the usual places. Thus, headers whose names
> are enclosed in double-quotes ( "" ) shall be searched for first in
> the directory of the file with the #include line, then in directories
> named in -I options, and last in the usual places. For headers whose
> names are enclosed in angle brackets ( "<>" ), the header shall be
> searched for only in directories named in -I options and then in the
> usual places. Directories named in -I options shall be searched in the
> order specified.
> In lieu of a compiler doing it differently, it would be correct to
> #include <petscsnes.h> and #include "mylocalinclude.h" (or #include
> <../src/something/hereiman/mylocalinclude.h>, but I think the former is
> more maintainable). This is certainly the convention I see in almost
> all other projects. Is the current way of doing things dictated by
> strange compilers or the documentation tools?
> Jed
What most experimenters take for granted before they begin their experiments
is infinitely more interesting than any results to which their experiments
lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20100503/1534706d/attachment.html>
