[petsc-dev] reminder never use #include "mylocalinclude.h" in PETSc source
Jed Brown
jed at 59A2.org
Mon May 3 05:41:11 CDT 2010
On Sun, 2 May 2010 19:17:51 -0700, Barry Smith <bsmith at mcs.anl.gov> wrote:
> Reminder, don't use
> in the PETSc source, you should always make it relative the PETSC_DIR/
> include directory such as
> #include "../src/something/hereiman/mylocalinclude.h"
I'm confused. The standard doesn't say anything about the relative
meaning of <file.h> and "file.h", just that each involve an
implementation-defined search, and if the search for "file.h" fails,
then it should be searched for as if it had been <file.h>. But every
compiler I'm aware of follows the POSIX standard (quoting from the
description of -I):
Change the algorithm for searching for headers whose names are not
absolute pathnames to look in the directory named by the directory
pathname before looking in the usual places. Thus, headers whose names
are enclosed in double-quotes ( "" ) shall be searched for first in
the directory of the file with the #include line, then in directories
named in -I options, and last in the usual places. For headers whose
names are enclosed in angle brackets ( "<>" ), the header shall be
searched for only in directories named in -I options and then in the
usual places. Directories named in -I options shall be searched in the
order specified.
In lieu of a compiler doing it differently, it would be correct to
#include <petscsnes.h> and #include "mylocalinclude.h" (or #include
<../src/something/hereiman/mylocalinclude.h>, but I think the former is
more maintainable). This is certainly the convention I see in almost
all other projects. Is the current way of doing things dictated by
strange compilers or the documentation tools?
Jed
