[petsc-dev] [petsc-maint #49590] problem building petsc-dev
Satish Balay
balay at mcs.anl.gov
Fri Jul 16 21:09:14 CDT 2010
The previous change to pic default had this comment. [And this change
must have been done form some other petsc-maint issue. And I keep
forgetting senarios/issues when this was done]
5a0c830b3a17
-defaut pic=0 [shared=0]
- do pic check only when shared=1 or pic=1
- special pic check for borland is removed - as its no longer required for shared=0 [default]
So the primary issue with default-pic=1 is: its contradictary to
default-shared=0. [and will be tempted to rectify this contradiction a
couple of years from now again]
Satish
On Fri, 16 Jul 2010, Barry Smith wrote:
> Hmmm, I never use --with-pic=1
> Why don't we just enable pic by default. Then if user does --with-pic=0 --with-shared we complain. Better than always required shared people to use --with-pic. People who don't want to use --with-pic are far and few between.
> Barry
> >> I think Satish is right we should have
> >> --with-shared-libraries
> >> --with-dynamic-loading
> >> I haven't made this change but I've changed
> >> improved help message for --with-shared and --with-dynamic
> >> made --with-dynamic require --with-shared
> >> make --with-shared NOT allow --with-pic=0
> > Barry,
> > With this change one has to always do the following for sharedlibs:
> > --with-pic=1 --with-shared=1
> > and for dynamic libraries.
> > --with-pic=1 --with-shared=1 --with-dynamic=1
> > Earlier behavior was for --with-pic to be implicitly enabled for
> > with-shared or with-dynamic. It would be good to retain the old
> > behavior.
> > Part of the problem is: configure cannot distinguish between user
> > provided value vs configure default value - for any given option. So
> > we can't do both:
> > * default-pic=disabled but autoenable if user provides --with-shared=1
> > * if user provides '--with-pic=0 --with-shared=1' - flag as error.
> > [I didn't remember this part - when I started this thread about this
> > issue. Looks like we should silently ignore --with-pic - when
> > --with-shared is enabled]
> > Satish
> >> I'll change the option names in a little while
