[petsc-dev] [petsc-maint #49590] problem building petsc-dev
Barry Smith
bsmith at mcs.anl.gov
Fri Jul 16 20:50:38 CDT 2010
Hmmm, I never use --with-pic=1
Why don't we just enable pic by default. Then if user does --with-pic=0 --with-shared we complain. Better than always required shared people to use --with-pic. People who don't want to use --with-pic are far and few between.
Barry
On Jul 16, 2010, at 8:39 PM, Satish Balay wrote:
> On Fri, 16 Jul 2010, Barry Smith wrote:
>> I think Satish is right we should have
>> --with-shared-libraries
>> --with-dynamic-loading
>> I haven't made this change but I've changed
>> improved help message for --with-shared and --with-dynamic
>> made --with-dynamic require --with-shared
>> make --with-shared NOT allow --with-pic=0
> Barry,
> With this change one has to always do the following for sharedlibs:
> --with-pic=1 --with-shared=1
> and for dynamic libraries.
> --with-pic=1 --with-shared=1 --with-dynamic=1
> Earlier behavior was for --with-pic to be implicitly enabled for
> with-shared or with-dynamic. It would be good to retain the old
> behavior.
> Part of the problem is: configure cannot distinguish between user
> provided value vs configure default value - for any given option. So
> we can't do both:
> * default-pic=disabled but autoenable if user provides --with-shared=1
> * if user provides '--with-pic=0 --with-shared=1' - flag as error.
> [I didn't remember this part - when I started this thread about this
> issue. Looks like we should silently ignore --with-pic - when
> --with-shared is enabled]
> Satish
>> I'll change the option names in a little while
