[petsc-dev] [petsc-maint #49590] problem building petsc-dev
Barry Smith
bsmith at mcs.anl.gov
Fri Jul 16 21:15:24 CDT 2010
Hmm, maybe we should just require users to use --with-pic if they want to do shared libraries.
The other choice is to remove --with-pic completely and automatically look for pic flags ONLY if --with-shared is turned on?
Both match our standards; BUT --with-pic is a pain to always have to type in and it would be rare that one wants --with-pic but not --with-shared
Barry
On Jul 16, 2010, at 9:09 PM, Satish Balay wrote:
> The previous change to pic default had this comment. [And this change
> must have been done form some other petsc-maint issue. And I keep
> forgetting senarios/issues when this was done]
> 5a0c830b3a17
> -defaut pic=0 [shared=0]
> - do pic check only when shared=1 or pic=1
> - special pic check for borland is removed - as its no longer required for shared=0 [default]
> So the primary issue with default-pic=1 is: its contradictary to
> default-shared=0. [and will be tempted to rectify this contradiction a
> couple of years from now again]
> Satish
> On Fri, 16 Jul 2010, Barry Smith wrote:
>> Hmmm, I never use --with-pic=1
>> Why don't we just enable pic by default. Then if user does --with-pic=0 --with-shared we complain. Better than always required shared people to use --with-pic. People who don't want to use --with-pic are far and few between.
>> Barry
>>>> I think Satish is right we should have
>>>> --with-shared-libraries
>>>> --with-dynamic-loading
>>>> I haven't made this change but I've changed
>>>> improved help message for --with-shared and --with-dynamic
>>>> made --with-dynamic require --with-shared
>>>> make --with-shared NOT allow --with-pic=0
>>> Barry,
>>> With this change one has to always do the following for sharedlibs:
>>> --with-pic=1 --with-shared=1
>>> and for dynamic libraries.
>>> --with-pic=1 --with-shared=1 --with-dynamic=1
>>> Earlier behavior was for --with-pic to be implicitly enabled for
>>> with-shared or with-dynamic. It would be good to retain the old
>>> behavior.
>>> Part of the problem is: configure cannot distinguish between user
>>> provided value vs configure default value - for any given option. So
>>> we can't do both:
>>> * default-pic=disabled but autoenable if user provides --with-shared=1
>>> * if user provides '--with-pic=0 --with-shared=1' - flag as error.
>>> [I didn't remember this part - when I started this thread about this
>>> issue. Looks like we should silently ignore --with-pic - when
>>> --with-shared is enabled]
>>> Satish
>>>> I'll change the option names in a little while
