[petsc-dev] [petsc-maint #49590] problem building petsc-dev
    Satish Balay
    balay at mcs.anl.gov
    Fri Jul 16 20:39:08 CDT 2010
On Fri, 16 Jul 2010, Barry Smith wrote:
>   I think Satish is right we should have
> --with-shared-libraries
> --with-dynamic-loading
>   I haven't made this change but I've changed
> improved help message for --with-shared	and --with-dynamic
> made --with-dynamic require --with-shared
> make --with-shared NOT allow --with-pic=0
Barry,
With this change one has to always do the following for sharedlibs:
--with-pic=1 --with-shared=1
and for dynamic libraries.
--with-pic=1 --with-shared=1 --with-dynamic=1
Earlier behavior was for --with-pic to be implicitly enabled for
with-shared or with-dynamic. It would be good to retain the old
behavior.
Part of the problem is: configure cannot distinguish between user
provided value vs configure default value - for any given option. So
we can't do both:
* default-pic=disabled but  autoenable if  user provides --with-shared=1
* if user provides '--with-pic=0 --with-shared=1' - flag as error.
[I didn't remember this part - when I started this thread about this
issue. Looks like we should silently ignore --with-pic - when
--with-shared is enabled]
Satish
> I'll change the option names in a little while
