[petsc-dev] [petsc-maint #49590] problem building petsc-dev
Barry Smith
bsmith at mcs.anl.gov
Fri Jul 16 12:01:35 CDT 2010
I think Satish is right we should have
--with-shared-libraries
--with-dynamic-loading
I haven't made this change but I've changed
improved help message for --with-shared and --with-dynamic
made --with-dynamic require --with-shared
make --with-shared NOT allow --with-pic=0
I'll change the option names in a little while
Barry
On Jul 16, 2010, at 11:48 AM, Barry Smith wrote:
> We currently have
> self.useShared = (self.argDB['with-dynamic'] or self.argDB['with-shared']) and not self.setCompilers.staticLibraries
> in config/PETSc/utilities/sharedLibraries.py which allows dynamic libraries without shared libraries!
> I am fixing this and improving the help messages etc right now.
> Barry
> On Jul 16, 2010, at 9:13 AM, Satish Balay wrote:
>> Can you send the relavent configure.log?
>> Also the following doesn't make sense.
>> --without-pic \
>> --with-shared=0 \
>> --with-dynamic \
>> If you need dynamic - you also need shared. I guess these options are
>> a bit confusing on the Mac. Here dynamic does not imply .dylib. [If
>> you need .dylib - all you need is --with-shared=1] --with-dynamic=>
>> use dlopen() or equivalnet.
>> So suggest using:
>> --with-shared=1
>> or
>> --with-shared=1 --with-dynamic=1
>> Satish
>> On Fri, 16 Jul 2010, Michael Pernice wrote:
>>> Hi,
>>> This fails at the configure step with the error:
>>> Error in Sowing installation: Could not find /Users/pernma/packages/petsc/petsc-dev/macos/bin/bfort
>>> I have PETSC_ARCH set to macos and my configure script is attached (tried to exclude sowing in the latest attempt).
>>> Michael Pernice, Assistant Director
>>> Center for Advanced Modeling and Simulation
>>> Idaho National Laboratory
>>> P.O. Box 1625, MS 3550
>>> Idaho Falls, ID 83415-3550
>>> Phone: 208.526.9480
>>> Cell: 208.569.2252
>>> Fax: 208.526.8254
>>> www.inl.gov/cams
