[petsc-dev] Fwd: cmake issue
Matthew Knepley
knepley at gmail.com
Wed Dec 15 20:28:02 CST 2010
On Wed, Dec 15, 2010 at 12:59 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> Jed wrote
> As for the other issue (CC="gcc -m32" and such), would it be acceptable to
> make all of BuildSystem (instead of just the cmake part) convert that to,
> effectively, CC=gcc CFLAGS="-m32" LDFLAGS="-m32"?
> Matt and Satish,
> So if the user does --with-cc="gcc options" would it be ok if configure
> stripped those options from cc and stuck them into the CFLAGS and LDFLAGS
> variables of configure automatically? Or is there a problem with that>?
I see at least one problem with this, namely that 'options' would need to be
in CPPFLAGS if the C compiler
was being used as the preprocessor. I do not like this because the user told
us what they wanted. If they
wanted options in CFLAGS, its jsut as easy to put it there.
Matt
> Barry
What most experimenters take for granted before they begin their experiments
is infinitely more interesting than any results to which their experiments
lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20101215/741635ba/attachment.html>
