[petsc-dev] Fwd: cmake issue
    Barry Smith
    bsmith at mcs.anl.gov
    Wed Dec 15 20:41:02 CST 2010
On Dec 15, 2010, at 8:28 PM, Matthew Knepley wrote:
> On Wed, Dec 15, 2010 at 12:59 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>> Jed wrote
>> As for the other issue (CC="gcc -m32" and such), would it be acceptable to make all of BuildSystem (instead of just the cmake part) convert that to, effectively, CC=gcc CFLAGS="-m32" LDFLAGS="-m32"?
>   Matt and Satish,
>   So if the user does --with-cc="gcc options" would it be ok if configure stripped those options from cc and stuck them into the CFLAGS and LDFLAGS variables of configure automatically? Or is there a problem with that>?
> I see at least one problem with this, namely that 'options' would need to be in CPPFLAGS if the C compiler
> was being used as the preprocessor. I do not like this because the user told us what they wanted. If they
> wanted options in CFLAGS, its jsut as easy to put it there.
   Not true. I it is easy for me to remember --with-cc="gcc -m32"  but not easy for me to remember --with-cc=gcc CFLAGS="-m32" LDFLAGS="-m32"  and CPPFLAGS="-m32" !
   Note that configure/make handles what I do just fine but Jed's cmake had trouble and suggested changing configure to move the variables.
  Barry
>    Matt
>   Barry
> What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead.
> -- Norbert Wiener
