[petsc-dev] no module named cmakegen
    Satish Balay
    balay at mcs.anl.gov
    Mon Aug 23 08:42:44 CDT 2010
On Mon, 23 Aug 2010, Aron Ahmadia wrote:
> Hi Leo,
> I haven't seen this problem before.  What are you specifying to configure?
>  You may want to send the configure.log (after killing it) to
> petsc-maint at mcs.anl.gov.  I am not on that mailing list, but it's the right
> place to send potential bugs.
> Also, this goes without saying, but if you were doing anything strange, it's
> best to start with a clean copy of the repository (I don't know the *right*
> way to do this in Mercurial, but you can just do an hg clone of your
> petsc-dev into another directory)
Aron,
One can do the following:
cd petsc-dev
hg status
hg revert -a
hg pull -u
cd BuildSystem
hg status
hg revert -a
hg pull -u
Satish
> A
> On Mon, Aug 23, 2010 at 2:45 PM, Leo van Kampenhout <
> lvankampenhout at gmail.com> wrote:
> > Hi Aron,
> > I try now to configure the Mercurial version of Petsc-dev. However, the
> > script gets stuck in some kind of "infinite" loop, producing this text over
> > and over again. What should I do now?
> > -- The C compiler identification is GNU
> > -- Check for working C compiler: /opt/local/bin/mpicc
> > -- Check for working C compiler: /opt/local/bin/mpicc -- works
> > -- Detecting C compiler ABI info
> > -- Detecting C compiler ABI info - done
> > -- The Fortran compiler identification is GNU
> > -- Check for working Fortran compiler: mpif90
> > -- Check for working Fortran compiler: mpif90 -- works
> > -- Checking whether mpif90 supports Fortran 90
> > -- Checking whether mpif90 supports Fortran 90 -- yes
> > -- Configuring done
> > You have changed variables that require your cache to be deleted.
> > Configure will be re-run and you may have to reset some variables.
> > The following variables have changed:
> > CMAKE_Fortran_COMPILER= mpif90
> > Leo
> > 2010/8/23 Aron Ahmadia <aron at ahmadia.net>
> >> Hi Leo,
> >> Yes.
> >> A
> >> On Mon, Aug 23, 2010 at 2:19 PM, Leo van Kampenhout <
> >>> Hi Aron,
> >>> I'm using the nightly tarball. Do you propose using mercurial? I can try
> >>> that.
> >>> Leo
> >>> Hi Leo,
> >>>> Did you perform an "hg pull; hg update" in petsc-dev/config/BuildSystem?
> >>>> A
> >>>> On Mon, Aug 23, 2010 at 2:14 PM, Leo van Kampenhout <
> >>>>> Hi all,
> >>>>> I'm trying to install PETSc-dev on my desktop machine. This is what
> >>>>> goes wrong. I suspect the line
> >>>>>  import cmakegen [line 409]
> >>>>> in the configure.py is the cause. The version of Cmake installed on my
> >>>>> system is 2.6
> >>>>> Best regards,
> >>>>> Leo van Kampenhout
> >>>>> csg4035 at wingtip70:~/install/petsc-dev$ ./configure
> >>>>>              Configuring PETSc to compile on your
> >>>>> system
> >>>>> TESTING: configureFortranFlush from
> >>>>> PETSc.Configure(/net/users/csg/csg4035/download/petsc-dev/config/PETSc/Configure.py:652*******************************************************************************
> >>>>>                      UNABLE to FIND MODULE for ./configure
> >>>>> No module named cmakegen
