[petsc-dev] no module named cmakegen
    Aron Ahmadia
    aron at ahmadia.net
    Mon Aug 23 06:57:16 CDT 2010
Hi Leo,
I haven't seen this problem before.  What are you specifying to configure?
 You may want to send the configure.log (after killing it) to
petsc-maint at mcs.anl.gov.  I am not on that mailing list, but it's the right
place to send potential bugs.
Also, this goes without saying, but if you were doing anything strange, it's
best to start with a clean copy of the repository (I don't know the *right*
way to do this in Mercurial, but you can just do an hg clone of your
petsc-dev into another directory)
A
On Mon, Aug 23, 2010 at 2:45 PM, Leo van Kampenhout <
lvankampenhout at gmail.com> wrote:
> Hi Aron,
> I try now to configure the Mercurial version of Petsc-dev. However, the
> script gets stuck in some kind of "infinite" loop, producing this text over
> and over again. What should I do now?
> -- The C compiler identification is GNU
> -- Check for working C compiler: /opt/local/bin/mpicc
> -- Check for working C compiler: /opt/local/bin/mpicc -- works
> -- Detecting C compiler ABI info
> -- Detecting C compiler ABI info - done
> -- The Fortran compiler identification is GNU
> -- Check for working Fortran compiler: mpif90
> -- Check for working Fortran compiler: mpif90 -- works
> -- Checking whether mpif90 supports Fortran 90
> -- Checking whether mpif90 supports Fortran 90 -- yes
> -- Configuring done
> You have changed variables that require your cache to be deleted.
> Configure will be re-run and you may have to reset some variables.
> The following variables have changed:
> CMAKE_Fortran_COMPILER= mpif90
> Leo
> 2010/8/23 Aron Ahmadia <aron at ahmadia.net>
>> Hi Leo,
>> Yes.
>> A
>> On Mon, Aug 23, 2010 at 2:19 PM, Leo van Kampenhout <
>>> Hi Aron,
>>> I'm using the nightly tarball. Do you propose using mercurial? I can try
>>> that.
>>> Leo
>>> Hi Leo,
>>>> Did you perform an "hg pull; hg update" in petsc-dev/config/BuildSystem?
>>>> A
>>>> On Mon, Aug 23, 2010 at 2:14 PM, Leo van Kampenhout <
>>>>> Hi all,
>>>>> I'm trying to install PETSc-dev on my desktop machine. This is what
>>>>> goes wrong. I suspect the line
>>>>>  import cmakegen [line 409]
>>>>> in the configure.py is the cause. The version of Cmake installed on my
>>>>> system is 2.6
>>>>> Best regards,
>>>>> Leo van Kampenhout
>>>>> csg4035 at wingtip70:~/install/petsc-dev$ ./configure
>>>>>              Configuring PETSc to compile on your
>>>>> system
>>>>> TESTING: configureFortranFlush from
>>>>> PETSc.Configure(/net/users/csg/csg4035/download/petsc-dev/config/PETSc/Configure.py:652*******************************************************************************
>>>>>                      UNABLE to FIND MODULE for ./configure
>>>>> No module named cmakegen
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20100823/b35e86cc/attachment.html>
