[petsc-dev] no module named cmakegen
    Leo van Kampenhout
    lvankampenhout at gmail.com
    Mon Aug 23 06:19:16 CDT 2010
Hi Aron,
I'm using the nightly tarball. Do you propose using mercurial? I can try
that.
Leo
2010/8/23 Aron Ahmadia <aron at ahmadia.net>
> Hi Leo,
> Did you perform an "hg pull; hg update" in petsc-dev/config/BuildSystem?
> A
> On Mon, Aug 23, 2010 at 2:14 PM, Leo van Kampenhout <
> lvankampenhout at gmail.com> wrote:
>> Hi all,
>> I'm trying to install PETSc-dev on my desktop machine. This is what goes
>> wrong. I suspect the line
>>  import cmakegen [line 409]
>> in the configure.py is the cause. The version of Cmake installed on my
>> system is 2.6
>> Best regards,
>> Leo van Kampenhout
>> csg4035 at wingtip70:~/install/petsc-dev$ ./configure
>>              Configuring PETSc to compile on your
>> system
>> TESTING: configureFortranFlush from
>> PETSc.Configure(/net/users/csg/csg4035/download/petsc-dev/config/PETSc/Configure.py:652*******************************************************************************
>>                      UNABLE to FIND MODULE for ./configure
>> No module named cmakegen
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20100823/2eadc532/attachment.html>
