[petsc-dev] no module named cmakegen
    Aron Ahmadia
    aron at ahmadia.net
    Mon Aug 23 06:20:15 CDT 2010
Hi Leo,
Yes.
A
On Mon, Aug 23, 2010 at 2:19 PM, Leo van Kampenhout <
lvankampenhout at gmail.com> wrote:
> Hi Aron,
> I'm using the nightly tarball. Do you propose using mercurial? I can try
> that.
> Leo
> 2010/8/23 Aron Ahmadia <aron at ahmadia.net>
> Hi Leo,
>> Did you perform an "hg pull; hg update" in petsc-dev/config/BuildSystem?
>> A
>> On Mon, Aug 23, 2010 at 2:14 PM, Leo van Kampenhout <
>>> Hi all,
>>> I'm trying to install PETSc-dev on my desktop machine. This is what goes
>>> wrong. I suspect the line
>>>  import cmakegen [line 409]
>>> in the configure.py is the cause. The version of Cmake installed on my
>>> system is 2.6
>>> Best regards,
>>> Leo van Kampenhout
>>> csg4035 at wingtip70:~/install/petsc-dev$ ./configure
>>>              Configuring PETSc to compile on your
>>> system
>>> TESTING: configureFortranFlush from
>>> PETSc.Configure(/net/users/csg/csg4035/download/petsc-dev/config/PETSc/Configure.py:652*******************************************************************************
>>>                      UNABLE to FIND MODULE for ./configure
>>> No module named cmakegen
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20100823/4e86d927/attachment.html>
