[petsc-dev] no module named cmakegen
    Aron Ahmadia
    aron at ahmadia.net
    Mon Aug 23 06:17:37 CDT 2010
Hi Leo,
Did you perform an "hg pull; hg update" in petsc-dev/config/BuildSystem?
A
On Mon, Aug 23, 2010 at 2:14 PM, Leo van Kampenhout <
lvankampenhout at gmail.com> wrote:
> Hi all,
> I'm trying to install PETSc-dev on my desktop machine. This is what goes
> wrong. I suspect the line
>  import cmakegen [line 409]
> in the configure.py is the cause. The version of Cmake installed on my
> system is 2.6
> Best regards,
> Leo van Kampenhout
> csg4035 at wingtip70:~/install/petsc-dev$ ./configure
>              Configuring PETSc to compile on your
> system
> TESTING: configureFortranFlush from
> PETSc.Configure(/net/users/csg/csg4035/download/petsc-dev/config/PETSc/Configure.py:652*******************************************************************************
>                      UNABLE to FIND MODULE for ./configure
> No module named cmakegen
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20100823/4a4f4a0d/attachment.html>
