TS grand plan
Jed Brown
jed at 59A2.org
Thu Sep 24 14:47:55 CDT 2009
Lisandro Dalcin wrote:
> On Thu, Sep 24, 2009 at 10:00 AM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>> TSType is the only type that has _ in the middle (SNES, KSP etc etc do
>> not) therefor the correct fix is to remove the _
>> from the middle of all TSType names and you can follow all the rules :-)
>> Barry
> Agreed... we should change all the TS_<TYPENAME> to TS<TYPENAME> ...
Done
> However, I now think that we should have
> #define TS_GENERAL_LINEAR "general-linear"
> as we already have "crank-nicholson" and "runge-kutta" ...
Maybe, but all the other packages tend to use acronyms, cf. "asm", "cg",
"ls", versus "additive-schwarz", "conjugate-gradients", "line-search".
It's a bike shed at this point, and I don't care much although I do like
short names because it requires less typing to experiment on the command
line.
Jed
Desc: OpenPGP digital signature
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20090924/12964830/attachment.sig>
